Home > Faults & Fixes > 2005 2.7 rrs leaking diesel from injectors
Pauly14666
Ireland 2005 Range Rover Sport TDV6 HSE Java Black
I hope someone can help I noticed smoke coming from my engine so pulled over and there was diesel everywere. On the right side one of the leak of pipes came of from the injector ( the plastic part that the clip hold on and the rubber pipe on on) so put it back on all was fine at idle reved the engine popped back of so got a new one replaced all the pipes now it's leaking from the pipes put cable ties on them still leaking past at high idle it's like there is high pressure when it's not ment to be anyone any ideas I'm lost thank you in advance
Post #561963 Tue Jul 24 2018 10:38pm
