Home > General > Air con compressor removal - V8 Supercharged |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
download the workshop manual:
Sat Jul 14 2018 10:01am |
You sure it has gas i changed two on my disco 3 in 2 years so check it has gas first if you have not already |
Sat Jul 14 2018 2:03pm |
trafficman13 Member Since: 11 Oct 2016 Location: Wales Posts: 9 |
System is full mate. It came back on last week when it was a little cooler, running for a week. This week it's on and off as the temp is a little hotter.
Tue Aug 14 2018 8:27pm |
How do you know itโs full I thought mine was until the Aircon guy came as mine was on and off there was only 50 grams in it enough to work it but not make it cold so if you havenโt had it tested or if you can see what pressure is in the system itโs either your gas or maybe your compressor |
Tue Aug 14 2018 8:38pm |
Had 820g put in 6 weeks ago. Had it pressure tested and also the compressor checked out by an air con specialist. All working good.
Tue Aug 14 2018 8:49pm |
I would ask the Aircon specialist guy then tell him itโs stopped working can he come and tell you why not it may be easier as these cars are so sofisticated in the electronics |
Tue Aug 14 2018 9:01pm |
I know. Tell me about it !!!!!
Tue Aug 14 2018 9:03pm |
