Home > Maintenance & Modifications > Next question... ...new wire through bulkhead.
HughN
Wales
I'm still trying to install the twin fog/driving lights. There is a discontinuity in the wiring somewhere between the wire going into the pax-side fusebox and the fusebox under the bonnet. Plan 'B' is to install a new wire (it is just a wire that goes to ground when the switch is closed).
Even with the upper glovebox removed I can't see the back of the grommet in the bulkhead and I can't get a wire through from the engine side. My usual trick of some think PTFE tube with a stiff wire in it doesn't work.
Any suggestions?! Confused
Help! Big Cry
Post #561243 Thu Jul 12 2018 12:21pm
have you enabled the driving lights in the CCF file ?
Post #561244 Thu Jul 12 2018 12:34pm
HughN
Wales
Err, no. Embarassed
Is that what the picture of a laptop with WDS means in last item of the instructions? I assumed that was something to do with headlamp alignment (getting the car level or similar). Making sure the wiring worked before I cut holes in the bumper seemed a good idea.
Cripes, I didn't think this car was that sophisticated - the nav screen looks like it is based on a ZX Spectrum and it has wiring looms the girth of an anaconda.
Time for a drive to my local indie...
Thank you - that would never, ever, have crossed my mind.
Bow down
Post #561264 Thu Jul 12 2018 3:45pm
Why on earth they decided to put his function through a computer / config option I don't know.
Maybe so the dealer has to be paid! Laughing
The fog light circuit couldn't be any more basic if you tried !
Post #561288 Thu Jul 12 2018 9:06pm
