Home > General > Air suspension fault |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
This is a pure guess so please forgive me if I'm wrong but maybe after changing the front sensors the ECU will need calibrating with an IID tool or similar because, I'm guessing again, the car has lost it's reference point? 2016 RRS SVR Estoril Blue
Thu Jul 12 2018 4:38pm |
Deanh134 Member Since: 11 Jul 2018 Location: Durham Posts: 4 |
Thanksnfor the reply, I’ve tried to re calibrate the suspension but it won’t let me cause of the fault. |
Thu Jul 12 2018 7:12pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
do the fault codes give a clue?
Thu Jul 12 2018 9:01pm |
Yeah I got original part from Land Rover, I checked part. I need before I fitted them and also how many pins and wires ran int the sensor. I cannot remember the code but sure it said it was something to do with the voltage to the sensor. The right side was the same but a new sensor sorted that |
Thu Jul 12 2018 9:40pm |
wire broken to sensor then. or poor connection |
Thu Jul 12 2018 9:59pm |
That’s what I was thinking but a few people told me it won’t be that, I was going to change it anyways to rule that out |
Thu Jul 12 2018 10:06pm |
