Home > Technical > Whistling suspension? |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Does the compressor continuously run? 2012 5.0 SC AB
Tue Jul 03 2018 8:31am |
Get your indy to read the codes as there is a light on there will be a code |
Tue Jul 03 2018 9:11am |
RRS_FR Member Since: 22 Oct 2017 Location: 46700 + Dubai,UAE Posts: 22 |
How do I check re the compressor?
Tue Jul 03 2018 11:19am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Front off side is where the front air suspension valve block is located. That'd be the first place to look if you can't do a code read. Check for leaks from the valve block and from the pipes connecting to it.
Tue Jul 03 2018 4:53pm |
Update and thank you to all who helped!
Sun Aug 19 2018 6:34pm |
