Home > Technical > Cool box/fridge |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Mine certainly turn off with the ignition, although it is a facelift but I don't think that should make any difference.
Sun Jul 01 2018 12:16pm |
DEVON Member Since: 15 Apr 2016 Location: Bolton Posts: 264 |
Cheers Col
Sun Jul 01 2018 1:14pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Mine does not turn off with the ignition and yes it will drain the battery in about 18 hours if left on. Last month I parked the car at 8 in the evening and left a map light and the fridge on and the car would not start at 11 the next day. Battery still had enough power to unlock the car, light up the dash and do a slow turn on the starter but not enough to fire the car and after the first go - nothing.
Sun Jul 01 2018 2:04pm |
Thanks Garry
Sun Jul 01 2018 2:22pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8828 |
Strange. My old 08MY TDV8 used to turn the cooler cubby off when the ignition was off as does my 2012 SDV6. I seem to remember they did change the design of the cooler because of this issue. 2012 SDV6 - it's missing a couple of cylinders
Sun Jul 01 2018 4:47pm |
Cheers RRSTDV8
Sun Jul 01 2018 5:23pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
No problems on a 2012 sdv6 in terms of draining battery. |
Sun Jul 01 2018 6:52pm |
Does that mean yours doesn’t turn off with the ignition Farther Jack ? |
Sun Jul 01 2018 7:08pm |
I`m sure my light is blue Steve. |
Sun Jul 01 2018 7:24pm |
From what I have read on here Steve , some are blue and some green ?
Sun Jul 01 2018 7:57pm |
Sorry, probably should have been clearer. If I stop and switch off with it running it has never killed my battery. In fact a few times I have forgotten it was on until noticing the subtle noise it makes when you are stopped in traffic for example. |
Sun Jul 01 2018 8:01pm |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 410 |
I've just been out to mine (MY17), which has a factory fitted coolbox with a green light in the switch. It hasn't been used all day, the light is out (despite being switched on) and the cool box is at "room" temperature. On switching on the ignition, the green light illuminates. Mine is left permanently switched in the on position, with a couple of cans of diet coke and a couple of bottles of water in there, and I have never suffered from a flat battery even after leaving the car at the airport for a week whilst on holiday. RRS MY17 SDV6 AB
Sun Jul 01 2018 8:02pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
This will probably confuse matters but mine has a blue light and I'm sure it does not switch off with the ignition but maybe some time after the ignition is switched off.
Sun Jul 01 2018 8:13pm |
Hmmm the mystery continues
Sun Jul 01 2018 8:28pm |
