Home > Technical > How to get battery back on! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8829 |
Which battery did you buy? Why can't he refit it? Won't it physically fit or is there some other issue?
Wed Jun 27 2018 10:29pm |
Flinders Member Since: 12 Dec 2014 Location: West Yorkshire Posts: 123 |
After trying for an hour he finally says it’s too big for where it should go so I think the garage ordered the wrong one. They put the reg number in to get vehicle details so not sure how they can get the wrong battery.
Wed Jun 27 2018 10:35pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
90Ah should do it from memory. Or 100
Wed Jun 27 2018 10:59pm |
It's an 019 and is available in various outputs - the diesels require 90Ah / 825A. Go for a larger capacity to give a bit of leeway on cold starting etc. As I mentioned, it's possible the battery is the correct overall size but there can be a small lip or other protrusion that gets in the way. If in doubt, get one from Land Rover but expect silly money for it. 2012 SDV6 - it's missing a couple of cylinders
Thu Jun 28 2018 8:57am |
