Home > Technical > Did all L320s have TPMS |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Not all L320's have TPMS & if they have it (iifc) it doesn't work the same as L494 which shows each tyre pressure,,the L320 just flags up low tyre pressure but doesn't tell you which tyre.
Fri Jun 15 2018 8:08am |
I think in the UK TPMS was mandatory from Jan 2012 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Jun 15 2018 8:54am |
So mine has probably never had it and wouldn’t help much anyway. I think I have a small leak in one tyre and I can visually see when it’s down so will just have to stick to that method. Thanks for the reply. 2012 5.0 SC AB
Fri Jun 15 2018 8:56am |
You can always check your vehicle build spec on :-
Fri Jun 15 2018 9:09am |
I’ve already looked but it doesn’t say either way. If it doesn’t have something it says less xxxxxx (I.e. I don’t have a sunroof and it says “Less opening Roof panels”). So I can only assume it was not an option or fit. 2012 5.0 SC AB
Fri Jun 15 2018 9:20am |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
My December 2012 Autobiography doesn't have it, which I always thought was odd. Merc C220 estate Sport AMG
Fri Jun 15 2018 9:55am |
It is odd considering the AB is supposed to be the top of the line. 2012 5.0 SC AB
Fri Jun 15 2018 10:22am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
Mandatory from 1st November 2014, factory option on RRS1 have it on mine but pretty usless system really, only flashes warning if pressure drops below around 25psi., but does tell you which wheel, thats it.
Fri Jun 15 2018 10:30am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
I thought most supercharged ones had it. Obv. not. |
Fri Jun 15 2018 10:49am |
