Home > Faults & Fixes > 2005 Range Rover sport 4.2 v8 supercharged missfire issue |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
If it ran out of fuel it may be a fuel pump but it sounds like the cat may have collapsed and blocked the silencers. 2012 5.0 SC AB
Fri Jun 08 2018 9:37pm |
Shauny0809 Member Since: 01 Jun 2018 Location: Wigan Posts: 33 |
Would that cause missfire the drivers side cat is defiantly broke and I can hear big piece rattling and it can’t get past the bend on the exhaust |
Fri Jun 08 2018 9:47pm |
The emissions controls will be trying to adjust the mixture to get the emissions right which is probably why you have the misfire. Sounds like you will need two new cats as given the age of the car the other side might be worn out if unburned fuel has gone down it. It might cost more than the car is worth to rectify the problem as replacement cats are not cheap. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jun 09 2018 7:46am |
Yea the cats are exspensive but was thinking of getting the cats gutted out for now to see if it improves maybe see if like a gd mapper can alter the difference with out them in or something |
Sat Jun 09 2018 9:01am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
yeah I was thinking that.
Sat Jun 09 2018 9:25am |
Yea think that be best bet every car I’ve owned have had no cats due to being decated etc on my Subaru’s so any see why it much a difference for this as still petrol end of day |
Sat Jun 09 2018 10:01am |
C an you get some decat pipes made for it and see if that works |
Sat Jun 09 2018 12:24pm |
Happy happy the passenger side cat was blocked and broke she’s running perfect now thanks |
Sun Jun 10 2018 8:00pm |
gutted both cats ? |
Sun Jun 10 2018 9:29pm |
Yea I gutted the drivers side as that was the 1 wat was making a noise still was same after gutted it so I changed pump and filter today and that didn’t work so got off and was gonna break it until I fort I’ll just do the other side and as I was cutting into it it was like sand trickling out all the cat and half was blocked up etc. But I think Iknow the actual cause why it had done it when I did the pump there was only 1 pipe connected to the filter witch didn’t take any notice of until I installed the new 1 we had pipe not connected to anything so who ever done it hadn’t connected the pipe properly I don’t think to the filter hence the missfires to cause cats to go bad and then that caused bad cats so after reinstalling pump was same reduced proformance until I gutted the other cat and now she runs perfect and sounds awesome 😎 only problem I have now is there’s piece cat in the last centre box witch might have chopped out and straight pipes done to it oh and noticed my centre prop shaft bearing has gone so looking for tips on how replace that and if an easy inuf job thanks for all ur help thow |
Sun Jun 10 2018 10:05pm |
lucky you.
Mon Jun 11 2018 12:10pm |
