Home > Technical > Calibration height |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8841 |
Centre of wheel hub to underside of the arch. The heights are 462mm front, 463mm rear (although no doubt 460mm is used more often than not as it's an easy round number).
Mon Jun 04 2018 11:21pm |
Philhudd Member Since: 15 May 2018 Location: Bristol Posts: 7 |
Many thanks for the response
Tue Jun 05 2018 7:00am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
493mm & 483mm are for the 2007 on Fullfat Range Rover not the Sport.
Tue Jun 05 2018 7:46am |
Perfect thanks
Tue Jun 05 2018 7:54am |
paul2415 Member Since: 10 Nov 2014 Location: essex Posts: 59 |
My 2010 sport nearside rear sits approx 10-15mm lower than the offside,would it be worth me getting a IIDTOOL?,or am I in tolerance? Thanks |
Tue Jun 05 2018 8:41am |
Update
Tue Jun 05 2018 7:23pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
if i remember correctly tight tolerance ensures that all wheels are within 10mm, unsure what the tolerance is for standard setting. |
Wed Jun 06 2018 12:38pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
no, 3 mm tight setting and 10 mm standard RRS 3.0 SDV6 HSE Lux
Wed Jun 06 2018 1:35pm |
