Home > General > Has my RRS got air con? |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1232 |
If it has it will have "auto" in the centre of the 3 dials and to switch it off on the bottom right hand side underneath the right hand dial it will say ECO. I'd post a photo but I'm on the iPad, somebody may be along shortly.
Sun Jun 03 2018 8:15pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4755 |
yeah it will.
Sun Jun 03 2018 8:35pm |
It doesn’t just have aircon it has climate control......... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Jun 03 2018 10:07pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Turn both temperature dials to lo, press auto. The fans should go flat out and after a while it should blow cold. If it's not cold in a couple of mins, something is wrong |
Sun Jun 03 2018 10:35pm |
airc909 Member Since: 28 May 2018 Location: Coventry Posts: 112 |
cheers guys |
Mon Jun 04 2018 9:17am |
If the system is working and doesn’t need re-gassing or overhauling then it is best to set it to auto and set both sides to 20 or 21 - this isn’t a temperature by the way according to Land Rover it is purely a numerical setting.......... - and then just adjust the setting up or down as you feel you need more warm or cooling. FYI the two sides/ controllers cannot be linked in L320 RRS so you cannot turn one controller and both side adjust at the same setting like VW/Audi and BMW systems . Running the system all the time has two advantages -it dehumidifies the interior and keeps the system pressurized and lubricated - it is thermostatic and will cut in and out as necessary to maintain the set temperature. You cannot adjust the humidity control. Running the system all the time has next to no effect on fuel consumption even with the 2.7 V6 motor. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Jun 04 2018 9:37am |
