Home > Faults & Fixes > 2005 rrs 4.2 v8 supercharged missfire air leak
Shauny0809
Hi dunno if I’m in right place but I have Range Rover sport 4.2 v8 sc and I’m having trouble She’s gone into reduced proomance and getting missfire and I can hear a hissing noise witch sounds like the drivers side of the engine I have just bought new plugs and plan to fit them to moro but struggling with the hissing noise is it ment to be there or not the symptoms are it won’t really rev past 3k and u can only put ur foot on peddle light witch will gradually pick up speed if u put it on to much the car looses power and same with when going up hills it will lose power 😔
Post #557896 Fri Jun 01 2018 9:59am
Socast
You need to find the air leak and sort it, squirting a bit of easy start around the intake joints will tell you if its drawing air (the engine speed will increase). You obviously don't want to squirt lots as it's flammable and your exhaust manifolds can ignite it (so pro tip is to test when the engine is cold).
Check the oil filler cap is tight as well.
Post #557897 Fri Jun 01 2018 10:12am
Shauny0809
Ok thanks I will try this to night so shouldn’t be getting a hissing noise from engine
Post #557899 Fri Jun 01 2018 10:24am
Socast
Nope, fingers crossed it’s something simple. Start at the air filter and work your way back to the throttle body. If you have a leak after the throttle body repairs start to get expensive Big Cry
Post #557901 Fri Jun 01 2018 11:43am
Shauny0809
Ok thanks I’ll give it try to night hope not lol
Post #557903 Fri Jun 01 2018 11:50am
Shauny0809
Just been looking and the picture attached the pvc long pipe wat goes to back engine if I undo it on the valve and start the car put my thumb over it the hissing leak sound stops and when I re attach it u can hear the hissing again
Post #557929 Fri Jun 01 2018 6:29pm
Shauny0809
Just been reading and seems the jag engines have slight hissing due to the pipe or something and it’s normal I sprayed carb cleaner all over and no change in engine gonna fit new spark plugs to moro and hope for the best lol
Post #557934 Fri Jun 01 2018 7:07pm
Socast
You’ve found your leak then, it’s probably the pipe that’s split or a damaged ‘o’ ring. Check the pipe for leaks, if there aren’t any then it might be worth replacing the pcv valve.
Post #557941 Fri Jun 01 2018 7:59pm
Shauny0809
Update on the car changed plugs and noticed the coil pack on cylinder 2 been changed and isn’t Denso 1 so I Range car place up and couldn’t get a Denso 1 so bought another witch was suited to the car fitted it and still got the same problem reduced profirmance and car still like bucking and looses power mainly at 3k revs or on hills etc would u go for injectors next seemes like fuel problem I think as the way it doesn’t want to go under load but will rev up when in park 😔
Post #558001 Sat Jun 02 2018 4:54pm
Socast
It’s down to the air leak, there should be no hissing from the engine.
Get the fault codes read and it will point you in the right direction as I highly doubt that it’s an injector that’s not right, but rather than pulling the injector (pretty big job) try putting a can of BG44 fuel additive in, if it improves then it may well be a failing injector.
When adding the BG44 I usually wait till the fuel warning light comes on, put in the additive and £15/£20 of fuel. Run it till the fuel light comes on before filling it again.
Post #558004 Sat Jun 02 2018 6:07pm
Shauny0809
The hissing noise will stop when I put my hand over the pcv valve pipe but I think it’s just the noise it makes with the plastic pipe and it’s tricking my ears Otherwise the hissing near were number 2 cylinder is but not sure
Post #558006 Sat Jun 02 2018 6:11pm
Shauny0809
Is there any 1 close to Wigan with the 4.2v8 supercharged engine we’re can listen there engine
Post #558007 Sat Jun 02 2018 6:13pm
Socast
Block the pipe with some electical tape and go for a drive. See if that fixes it.
Post #558010 Sat Jun 02 2018 8:47pm
Shauny0809
Take it the pipe off the pcv and block the long pipe
Post #558012 Sat Jun 02 2018 9:41pm
Shauny0809
Just disconnected it and blocked the long pipe had no change I reset the engine light so went off and went round corner and reduced proformance came back on when trying to take it over 3k revs think might be fuel issue as seems to Langton 1s it gets to 3k like it’s looking for fuel
Post #558014 Sat Jun 02 2018 10:05pm
