Home > Technical > Reduced Performance
nebc100
Luxembourg 2008 Range Rover Sport TDV6 HSE Java Black
Reduced Performance
Hello All,
Strange one... I have 3 times now been driving and get a "reduced engine performance" on the display.
If I restart the engine, everything is fine.
If I check with IID tool, there are no errors related to the engine, gearbox etc.
Do you have any ideas what I should check?
Post #557678 Tue May 29 2018 5:45pm
geoffsnook
intercooler and hoses and look for any black smoke out the back Thumbs Up
Post #557679 Tue May 29 2018 6:03pm
nebc100
No smoke. Will check hoses and intercooler, but surely if it was the intercooler, would I not get it almost permanently?
Today I had to leaving work, and then drove 50kms perfectly.
Post #557683 Tue May 29 2018 6:35pm
geoffsnook
No not all the time only when you put your foot down
Post #557689 Tue May 29 2018 7:21pm
nebc100
tried this evening... put foot down (hard), and car shoots forwards, but NO SMOKE at all.
I do have a DPF though!!
Post #557701 Tue May 29 2018 8:52pm
Andrewuk1986
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I’ve had a split intake manifold ( there’s 2 of em! )
Couldn’t see the split but under throttle it don’t have give out some air
Post #557750 Wed May 30 2018 3:42pm
Father Jack
Could be a range of problems but like Andrew above split intake manifold was my issue. Quick trip to local indy and soon diagnosed.
Post #557782 Wed May 30 2018 7:30pm
nebc100
Drove fine all day (approx. 100Km), and then suddenly gave an error this evening.
I left the engine on, plugged in IID, and got the error: P023D-22
I cleared this error, and engine ran fine afterwards.
So... it could be the sensor, pipe, intercooler or even turbo.
I will start by cleaning the sensor, and if necessary replacing that first, but I will keep you informed.
Post #557795 Wed May 30 2018 9:16pm
d-9
Iirc -22 is over boost, I used to see that when my inlet manifold was cracked and there was a boost leak. A week or so later it blew a hole big enough to get your thumb in and we diagnosed the problem Laughing
There are other likely places that boost leaks can happen, and this thread might be useful http://www.rrsport.co.uk/forum/post522326.html
Post #557799 Wed May 30 2018 11:01pm
Father Jack
Ref potential turbo failure all I can say is when my SDV6 ate BOTH the f Censored ers at the same time the car simply shut off straight away. At 40mph. Coasted to a stop. Scary, but had I being doing my usual 70mph (plus some margin for error Laughing ) up the M74 I'd have a tan coloured drivers seat now with the rest still being the original spec black.
Somewhere north of £3.5k later all fixed. It shutting off and me not trying to crank it or anything but having it recovered straight to my local indy saved the engine.
Post #557802 Thu May 31 2018 12:03am
nebc100
am starting to get this sorted. I have ordered new pipes to make sure that it isn't these.
When you say that it could be the inlet manifold, do you mean part LR032723 or LR032724?
Thanks.
Nick
Post #558427 Thu Jun 07 2018 9:57pm
