Home > Maintenance & Modifications > How often should I change the timing chain on 2008 3.6 TDV8 |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
How often should I change the timing chain on 2008 3.6 TDV8 current miles 131,200
Mon May 28 2018 2:39pm |
Mon May 28 2018 4:00pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
The belts are also fit for life - they should just be checked for wear and replaced as needed. Mine, so far as I am aware, was on its original belts and pulleys when I sold it. Similarly the water pump, I think. Mine had two alternators and a PAS pump replaced and the belts weren't ever changed. There might have been a new tensioner but I can't remember now. The paperwork all went to the new owner.
Mon May 28 2018 4:18pm |
MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Mon May 28 2018 4:21pm |
waynescott523 Member Since: 09 Jun 2018 Location: Southport Posts: 61 |
IM LOOKING AT FITTING SOME SORT OF WIFI INTO MY 3.6 TDV8 HST, I have rear entertainment screens in the back headrests any advice on which product is best for playing sky go ect on the screens would be appreciated.
Sat Jun 09 2018 10:42am |
Hi pal pm me your mobile and I will call you
Sat Jun 09 2018 10:49am |
