Home > Technical > Overheating - Water Pump Wiring / Cooling Fan |
Smartie Member Since: 31 Oct 2017 Location: Kummerfeld near Hamburg Posts: 6 |
Hi,
Mon May 28 2018 11:01am |
Ok. thanx Geoff, limits it to sensor or fan! |
Tue May 29 2018 3:11pm |
heck your fan is working it should sound noisy when you start the car and then quiet and when iy starts to get hot you should hear it if it come on but it does sound like the viscous is maybe not working correctly if it only does it in traffic |
Tue May 29 2018 6:26pm |
Thanx Geoff,
Wed May 30 2018 9:34am |
Some say if you can hold the fan when it’s supposed to be on when temp is high it means the viscous is knackered but never had the bottle to try to be honest |
Wed May 30 2018 10:10am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
and if it chops your fingers off its working ok |
Wed May 30 2018 11:02am |
And that’s why I never did it |
Wed May 30 2018 11:19am |
and 350 quid for a new fan is cheaper than prosthetic fingers! |
Thu May 31 2018 5:20am |
