Home > General (L494) > Advice on wheel corrosion |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 867 |
Maybe the previous owner has been using an acid based cleaner like Wonder Wheels which does lift the lacquer if used a lot or left on too long. |
Fri May 18 2018 12:21pm |
Darbs Member Since: 03 Dec 2015 Location: Cheshire Posts: 96 |
Hi, this is what happened all four off my wheels. Replaced under warranty with no hassle also had the rear brake calipers done due to flaking paint.
Fri May 18 2018 2:44pm |
Geedubu187 Member Since: 11 Aug 2017 Location: Lancashire Posts: 28 |
Thanks for the replies, never used wonder wheels or anything like that. Only had the car cleaned by someone else when it was at the dealers so it might have happened there but I didn't think they used anything but dirty water and a yard brush
Fri May 18 2018 4:02pm |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
I’ve recently sold a 3 series that had diamond cut wheels. They are prone to corrosion but if it happened during the warranty period then bmw would replace them without question. Be interesting to see if JLR feel the same way. I think you should ask for them to be replaced and take it from there... Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Fri May 18 2018 9:50pm |
Well I've been to dealer and initially all seemed good, yes covered under warranty by replacement until I mentioned that it was the LR approved warranty as car is now 3 1/2 years old. Sudden change of answer, not covered as it will not cover cosmetic damage.
Tue May 22 2018 5:39pm |
My car was on an extended warranty and replaced no problems! Guy Salmon at Knutsford did it and I didn’t buy it from them. I would be asking some more questions as it can’t be one rule for one and not another. I would be fuming 😡 not as though they are cheap ! |
Tue May 22 2018 6:28pm |
Dealers can be really inconsistent. I’d try another dealer, you never know.... Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY Range Rover sport HSE Dynamic P400e Silver Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY Range Rover sport 3.6tdv8HSE 2007 Gone Range Rover sport 2.7tdv6SE 2005 Gone Range Rover sport 2.7tdv6SE 2007 honey Range rover Vogue 2005 4.4 - GONE and missed BMW 535d M sport 2006 - GONE not as missed BMW X5 4.4 2004 sport - GONE |
Tue May 22 2018 9:51pm |
