Home > General > Dash Cam - which one? |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3675 |
Hi,ive got the Thinkware 770 with rear facing camera & find it very easy to use & can either be hard wired or cigarette light socket.
Mon May 14 2018 8:38am |
This is mine http://www.dx.com/p/viofo-a119s-v2-capacit...vlSVy0vyUk
Mon May 14 2018 10:10am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Thinkware 770 for me as well, easy to install with hard wire kit and so far very reliable. I used two piggy back fuses as it needs a permanent live for parked recording. They are not cheap but get good reviews. |
Mon May 14 2018 11:09am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 310 |
Thanks for that Steve!! Did you install it yourself? I'm just wondering if it needs a call in at my local garage or perhaps DIY. Does it come with all the required wires etc. Andrew Andrew Kennedy |
Mon May 14 2018 11:11am |
I took mine to a local auto elec. Charged me £30...not worth the hassle I had to buy a hard wire kit off ebay for a tenner. Steve. |
Mon May 14 2018 12:48pm |
Having a look on line, the THINKWARE F770 DASH CAM for front and rear windows looks a good system?!? Anyone out there any experience with this model and make?? Andrew Kennedy |
Mon May 14 2018 3:03pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
If you're going to install it yourself like I did, check the input voltage of the camera as most of them I believe are 5v and you will fry it if you hard wire it into the 12v electrics.
Mon May 14 2018 3:36pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Have had the F770 Front and Rear cameras fitted for 2/3 years now and never had any problems at all, has some good features included i.e. speed camera location etc, 12volt so easy to wire straight in. Will also accept a 128gb card (only certain one's though) although spec. says 64gb max. Not the cheapest on the market though, but personally think its one of the best and worth it.
Mon May 14 2018 11:43pm |
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 |
Hi there, I recently fitted a Cobra IP dashcam to my '08 RRS - full install guide at the of this thread:
Tue May 15 2018 11:16am |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
I recently did the Mini 0906 dual dashcam ( currently installed in both our RRS and X1 )
Fri May 18 2018 8:49am |
Auto-Express this week has a big test of dash cams that you might like to read before deciding which one to buy.
Fri May 18 2018 9:05am |
ilard Member Since: 20 Aug 2010 Location: London Posts: 972 |
Autoexpress’s photo of the Blackvue bracket upside down is triggering an OCD attack here. But clearly the best money-no-object camera. Right? My only concern is the bandwidth (and therefore time) it would take to upload a parking incident. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Tue May 22 2018 8:33pm |
Mine died after 12 months. Steve. |
Tue May 22 2018 8:36pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
Picked up a cam that clips onto rear view mirror and rear cam for 35 quid on ebay and another tenner for a hardwire kit. Full hd and audio. Hardest part of fitting was piggybacking the fuse as those fuses are tiny and the wee red fuse extractor tool is a pile of keech, skinny long nose pliers rule. |
Wed May 23 2018 8:19am |
