Home > Technical > Noisy Tailgate
Page 6 of 7 <1234567>
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Frisco_TX_RRS wrote:
Just called the dealer. They have never heard of the latch repair kit - they said they will just adjust the rubber stops to stop the noise
Told him there was a TSB, he was not aware of it - need to stick the TSB in his face.
Thanks,
TS
That's complete rubbish, I have it fitted on my car. It is quite new, only last 3 or 4 months, and there's not much to it.., BUT IT DOES EXIST!!! Your lazy Dealer cant be bothered to do his research!
Umbertob will put it right, he's really clued-up! Let us know the outcome, fingers crossed! Thumbs Up MY12 SDV6 HSE Sumatra/Ebony/Piano/Sidesteps/Privacy/Overfinch Olympus/JLR DRLs
Post #103687 Thu Apr 19 2007 9:33pm
Mintleaf
This fix is brilliant! i picked up my 2007 Sport last week and that noise has been bugging me - i just went out to Tesco and bought some velcro and the the noise is a million times better! Thanks RR Sport TDV6 HSE 07MY Java Black
Post #185769 Thu Aug 28 2008 9:20pm
Worth a small donation to the site? Thumbs Up
Post #185799 Fri Aug 29 2008 8:39am
Smiffy
Just thought I would add my thanks to Brian for pointing me in the right direction in terms of his rattly tailgate solution. It may help other sufferers to know that due to a lack of Velcro in my garage, I applied a slightly different solution which has worked equally well.
Instead of using Velco, I used two small rectangles of sticky-backed felt (normally available in small sheets from most DIY sheds). Rather than applying them to the plastic lock casing (as shown in Brian's photos), I placed each of the pieces of felt on the plastic lugs which sit on either side of the fixed part of the lock - at the bottom of the door sill (into which the bit in Brian's photo fits when the tailgate is closed).
The end effect is the same, as when the tailgate is closed the felt or Velcro are actually in the same spot. It did occur to me that there may be less chance of the felt being accidently knocked off where I have put it.
Anyway, well done Brian!
Post #186876 Thu Sep 04 2008 7:46pm
afewbeers
A big thanks for this tip, it used to really irritate me but with all the other problems I've had with the car I felt a bit embarrassed to moan about a bit of a rattle from the tailgate.
Post #195898 Thu Nov 13 2008 1:11am
Beasty
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
A big thanks from me too for this info. It has got rid of the worst bit of the noise from my rear Embarassed . I'm told by my stealer that I have some loose trim that needs a new clip that will get rid of the last bit of the rattle from the back. Then it will be rattle free driving Very Happy 06 2.7 HSE Bonatti Grey - 'Beasty'
Post #275336 Sat Sep 04 2010 7:30am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Could somebody please forward me the TSB for the LATCH REPAIR KIT?
I'm dealing with spanish dealers... Big Cry
The only thing they say is: QUE??? ET ESUH EBEH????? Rolling with laughter
Cheers. SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #275356 Sat Sep 04 2010 12:31pm
Bobby
Skywalker, sorry I could not find anything in Spanish! Big Cry
Have THIS in English though!! Laughing
Hope it helps!!! Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #275360 Sat Sep 04 2010 1:03pm
SkyWalker
Cheers Bobby! Thumbs Up SW
Post #275636 Wed Sep 08 2010 11:09pm
Vadim
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Hi guys, my RRS has been to a dealer recently to fix the tailgate upper section as it would not close properly. Now it has been fixed, a new latch was installed and now I have exact the same problem. Absolutely gutted, as suspension noise has just been fixed and now there is a new noise... Will have a look at it later today, and probably will have to take it back to LPR. Vadim A.
Post #282975 Tue Dec 14 2010 6:45am
Vadim
So it checked the tailgate just as the TSB LTB00006V2 says, and the striker loop ha no black coating. Since the new latch was installed by LPR it makes the metallic rattle noise... I will be taking it back for the fix. Damn it! Big Cry LPR is quite far away from me. But I guess once it will be fixed, the car will be dead quiet Bow down Vadim A.
Post #283144 Wed Dec 15 2010 11:32pm
bradtarga34
That must be really disappointing, especially as LPR are regarded as one of the best there is for looking after our pride and joys... On the plus side, I bet you are enjoying the lack of noise from the front end!
Post #283146 Thu Dec 16 2010 12:25am
Vadim
Oh no, don't get me wrong, I am very happy with the service at LRP. Although the tailgate problem appeared after installing the new latch, which obviously was necessary and the actual problem affects random cars, there is no way they could have known my car would be affected. So no hard feelings there, I still will come back to them and will recommend them to a friend. Vadim A.
Post #283150 Thu Dec 16 2010 3:50am
Vadim
Finally, got my RRS to LPR. Checked the tailgate several times and realised that the plastic bit, which had to be removed to install a new latch into the upper tailgate section, was not installed back properly and there was a big gap between the plastic cover and the actual door itself, as if the cover did not align with the door properly. Also, I noticed a small damage to the plastic cover right where the gap is at its biggest. My RRS is 6 months old and I know it inch by inch and I know the gap was not there, but appeared after installing the new latch.
TBH it is quite difficult to understand what kind of noise I get: metallic or plastic rattling, but sounds more like plastic. If upper section is opened and if some force is applied on the lower section from inside, there is a noticeable noise, sounds like plastic rattling. While at LPR I checked another brand new RRS in the same way by pushing on the lower section alone from inside, there was no noise whatsoever... So I will be looking for the same result on my RRS Yawn i.e. exactly as it was before. Vadim A.
Post #283799 Wed Dec 22 2010 4:18pm
Meiang
Tailgate Rattle Fix
To fix the tail gate rattle do the following:
Remove plastic trim over the power latch assembly (pull straight up to remove)
Under you will find two wedge rubber buffers. The problem is these move when you go over a bump causing the loop catch to move away from the the striker loop.
The solution is to place packers behind the wedges so that they dont move and the tail gate lock is always in tension when the power lock pulls it closed.
This fixed my problem like a dream. It also allows you to adjust the lock so that the tailgate is easy to close.
No more daggy velco strips required.
I also had a squeaky glass hatch which was caused by the hatch being badly adjusted from the factory and it was touching the bodywork when closed (people adjust the stoppers out to stop the squeaking but this causes the hatch hard to be hard to close). There is only 2-5mm clearance on either side. Adjusting the alignment fixed that problem. Again a very easy problem to fix.
Post #342939 Tue May 08 2012 4:30pm
