Home > In Car Electronics > Auto Detailer damaged the radio LCD display (SOLVED) |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 575 |
Try a hairdryer |
Thu Apr 26 2018 8:52pm |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 |
That’s liquid behind the lcd screen (seems obvious)
Thu Apr 26 2018 9:32pm |
Xrover Member Since: 08 Feb 2018 Location: Palm Desert Posts: 31 |
Red Arrow; That was the first thing I tried 2 days ago.
Thu Apr 26 2018 10:06pm |
My two-pennyworth: do the marks move when you press the screen, if so then it’s liquid. If no movement then damage to the screen caused by incorrect cleaner - may be?? Robin
Thu Apr 26 2018 10:41pm |
Nothing moves or changes shape when I move my finger on the screen (with light pressure) 2006 LR3 HSE
Thu Apr 26 2018 11:34pm |
So I would vote for screen damage as I suggested previously. I damaged my wife’s dell computer screen when I used a standard glass cleaner on it hence my suggestion. Perhaps they were cleaning the dashboard and didn’t blank off the screen and got overspray?? Anyone else heard of screen damage caused by incorrect solvent use?
Thu Apr 26 2018 11:38pm |
Manual say's warm water and non detergent soap. 2006 LR3 HSE
Thu Apr 26 2018 11:53pm |
Hmm. Yes. Not wishing to point the finger at your detailers, but the screen sounds like it would be susceptible to harsh chemicals......
Thu Apr 26 2018 11:58pm |
I can't prove it but it was perfectly clear before I brought it to them.
Fri Apr 27 2018 12:37am |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 323 |
Its liquid behind, check the two pictures, it is already different, so it moves and can be dried out. 2012 RRS HSE SDV6, BOURNVILLE 12/12-10/14
Fri Apr 27 2018 6:30am |
I decided to pull out the radio head unit and try to disassemble the LCD display to see if i could clean off the blotches.
Sat Apr 28 2018 1:48am |
Well done. Good work and good reference for others. Glad it’s sorted. Robin
Sat Apr 28 2018 6:55am |
2006 LR3 HSE
Sat Apr 28 2018 7:27am |
Go back to the guy and tell him you fixed it yourself at no cost. And let him know he should be more careful with screens in the future. Ask him if you can see what dash cleaner he uses, I bet it’s a silicone based polish to give the plastic a sheen. Accidents do happen and he probably does believe it wasn’t him but if he can’t say 100% he protected the screen then he can’t 100% say it wasn’t him. An apology would be nice. 2012 5.0 SC AB
Sat Apr 28 2018 8:07am |
