Home > Faults & Fixes > Removing/fixing trim |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
The Front door lower trims just pull off, Rear one's the same except there is a self tapper screw as well at the back edge, may be concealed by the rubber seal, would advise getting some spare new clips first as well as these are prone to breaking, there are two different type of clips for the Front door for some reason the black one's are used at the end of the trims the yellow/white one's do the rest. The lower wing trim also has a couple of screws right underneath it locates in the sill trim as well but uses same clips.
Mon Apr 23 2018 10:54pm |
