Home > Technical > Steering/wheeel/diff noise?
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
My 2010 RRS is making a strange noise and it’s been getting progressively worse for the last few weeks. When driving straight and especially with any right turn pressure in the steering wheel there is a sort of rhythmic throbbing noise which can also be felt faintly through the wheel. The frequency of the ‘throb’ is related to road speed, not engine speed. Interestingly, as soon as you apply any left pressure to the wheel the noise completely disappears. My independent garage suspects the diff, but then they didn’t actually hear the noise (long story). So, any thoughts on what the noise is?
I’m a complete amateur at all this, but as an ignoramus I would have guessed it was something like a wheel bearing.
(I’m 99% sure it is nothing to do with the power steering system. It doesn’t feel or sound like that)
Post #554638 Fri Apr 20 2018 8:13am
squizzel
From what you describe it sounds more like a wheel bearing or CV joint than the diff to me.
Post #554886 Mon Apr 23 2018 8:06pm
geoffsnook
More like a bearing noise especially as it goes when one lock is applied Thumbs Up
Post #554888 Mon Apr 23 2018 8:15pm
Brit Plumber
You could try putting it in neutral and let it coast. Without load on the CV joint the noise should change if it’s at fault. If it’s a bearing the noise will remain consistent. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #554890 Mon Apr 23 2018 8:22pm
foxtrotzulu
Thanks for the replies. They make more sense to me than the diff.
Post #555034 Wed Apr 25 2018 3:08pm
foxtrotzulu
Noise continues when I put the car in neutral and coast. Does this confirm it can't be the diff?
Post #555117 Thu Apr 26 2018 4:23pm
foxtrotzulu
Wheel bearing changed. All sorted!
Post #556112 Thu May 10 2018 7:27am
