Home > Maintenance & Modifications > Gear selector surround removal |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
I think you are meant to use the loop on the jack handle. (if you can get it in)
Sat Apr 14 2018 3:52pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
Do you think, looking at the location of the loop, that it’s possible to attach a lanyard to it permanently (i.e. a red loop of webbing etc.) and place it under the cap in the cup holder? Would the angle of the cable prevent it?
Sat Apr 14 2018 8:49pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
You'll probably have to give it a try just to see how far it pulls the loop across. It's not directly under the EPB switch anyway so it may well work,,,, or just keep a small Phillips driver in the boot as you can prise the gaiter off with your fingers 2010 RRS, TDV8
Sat Apr 14 2018 9:14pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Thanks for that, the plan was to loop a cable tie through the wire loop for a bit of leverage. |
Sat Apr 14 2018 9:56pm |
