Home > General > RRS ride quality comparison. |
grey17 Member Since: 18 Jul 2016 Location: London Posts: 62 |
RRS 05-09 vs facelift 2010 TDV8.
Fri Apr 13 2018 5:47pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
I found lowering the (rear) tyre pressures made a massive difference.
Fri Apr 13 2018 6:19pm |
Thanks Andy. I'm running mine at 32 psi all 'round at the moment and you're right, lowering the rear pressures help a lot.
Fri Apr 13 2018 9:46pm |
wilchesth Member Since: 11 Mar 2018 Location: Falmouth Posts: 41 |
Good tip! I’m on 20” and I also find it a bit stiff and I’ve got 33psi at the front and 36psi at the rear. Will try that tomorrow. Unless anybody here thinks it is a bad idea? 2008 Range Rover Sport 2.7 SE Zermatt Silver. |
Fri Apr 13 2018 9:56pm |
I think there are about 4 pressure options on the label inside the door.
Fri Apr 13 2018 10:53pm |
I've totally rebuilt the suspension with all new shock absorber and air bag assemblies as well as ride height sensors, ace bars and compressor! Its as near new handling as its ever been after the previous owners neglected it. Is the dynamic mode something that can be switched off? Thanks |
Sat Apr 14 2018 1:10pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Then very strange that you are experiencing a harsh ride with a new suspension. I can’t point my finger at anything else but then I’m no expert.
Sat Apr 14 2018 7:48pm |
I run 255/55/19, no issues here at standard pressures of 36R/33F, but at towing pressures of 42R/38F it is a little harsh so I drop the back down as soon as my heavy load is finished with 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Apr 14 2018 8:20pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
"Yours is a 2010 so won’t have the dynamic mode. It came in from MY12 onwards."
Sun Apr 15 2018 3:56am |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
I have a 2010 tdv6 and it has the dynamic mode with adaptive dampers.
Sun Apr 15 2018 8:17am |
Not “dynamic response” but “dynamic mode” that can be switched on and off using a button next to the terrain response dial? Surprised this was available in pre MY12 cars. Always thought it came in from MY12 Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Sun Apr 15 2018 8:27am |
Yes mine has dynamic response (arc) and dynamic mode . |
Sun Apr 15 2018 8:38am |
I must be confused that it was introduced at the same time as the 8 speed gearbox and SDV6 (as opposed to TDV6) engine. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Sun Apr 15 2018 9:12am |
I think I might have to go back to 19" rims but shame there are only two styles that fit over the calipers.... At least the spare will then correctly match for size Thanks G |
Sun Apr 15 2018 5:23pm |
