Home > General > Tdv8 oil leak |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8826 |
Is it engine oil (black) or a lighter coloured oil? If engine oil, it could be from the turbo or the PCV pipe. Light coloured oil could be dynamic response system. 2012 SDV6 - it's missing a couple of cylinders
Fri Apr 13 2018 7:04pm |
RRSV8 Member Since: 18 Mar 2018 Location: nottingham Posts: 56 |
Checked engine bay fluids & dynamic fluid on right side near airbox
Fri Apr 13 2018 8:16pm |
Depends where it's leaking. The pipes themselves aren't that easy to do, I believe, as they're well buried. The pump is also well buried and requires the generator (alternator) to be removed first. Probably needs to go on a ramp and a good look to establish exactly where it's leaking first. It's the sort of job that has a big labour cost because the pipes aren't easy to get at. 2012 SDV6 - it's missing a couple of cylinders
Fri Apr 13 2018 9:22pm |
Hey guys
Fri May 11 2018 8:12pm |
