Home > Faults & Fixes > RRS 2008 - limp mode solutions |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
I believe low battery could cause it, but i would also get the alternator checked. do you have a multimeter or GAP diagnostic tool so you can check yourself? |
Thu Apr 12 2018 5:43pm |
aldhous Member Since: 12 Apr 2018 Location: Hove Posts: 5 |
Thanks for the reply.
Thu Apr 12 2018 5:49pm |
ok, get yourself a cheep multimeter for now and measure the battery voltage with both the engine running (alternator) and stopped (battery)
Thu Apr 12 2018 5:55pm |
That's superb, thanks. Much appreciated - I'll get to it tomorrow. |
Thu Apr 12 2018 6:39pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Along with a possible battery charging issue, from experience I’d go along with the two faults pointing towards a suspension compressor problem and ACE fluid leak.
Thu Apr 12 2018 8:18pm |
Thank you.
Thu Apr 12 2018 8:56pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Suggest buying an iid tool |
Thu Apr 12 2018 9:34pm |
Bit of an update here. I put the key in this morning and at first only two warning lights came up:
Fri Apr 13 2018 7:26am |
