Home > In Car Electronics > Broken Dab arial |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
I didn't even realise a 06 plate car even have dab radio, thought it came in with the facelift.
Wed Apr 11 2018 9:11pm |
doyleywood Member Since: 09 Feb 2018 Location: Rossendale lancashire Posts: 18 |
Same here, but the arial defo dab connection. |
Wed Apr 11 2018 9:20pm |
Might be worth posting a photo of the damaged plug, could help identify it to see if it can be replaced.
Wed Apr 11 2018 9:57pm |
Factory wiring really tight, hard to get the plug to line up square while holding the head unit up close. |
Thu Apr 12 2018 8:47am |
See photos in gallery |
Thu Apr 12 2018 9:17am |
Thu Apr 12 2018 9:44am |
It's not DAB, but it is very similar to a fakra connector, that plug looks well and truly goosed though.
Thu Apr 12 2018 12:03pm |
That is a Fakra plug the colour of it will tell you which one you need, unless you use a sort of Aqua coloured one which is universal fit. As said that will be a real pain to solder and crimp in do in situ. due to limited room I would think.
Thu Apr 12 2018 12:40pm |
Oh right, that explains why the plug would not fit the dab unit i was trying to fit, hence the damage! Where could i buy this fitting? |
Thu Apr 12 2018 12:42pm |
Could Google Fakra Connector and see what comes up, sure I got some off Amazon in days gone bye or possibly ebay.
Thu Apr 12 2018 12:48pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
i think martin might sell these in the forum 'shop'.... |
Thu Apr 12 2018 3:38pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
look for a right angled connector though as a straight may foul something to the rear.. |
Thu Apr 12 2018 5:40pm |
May be a pain but if your fitting a DAB head unit, why don’t you fit a dab aerial and save fixing that one? 2012 5.0 SC AB
Thu Apr 12 2018 6:58pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Agree fit a proper DAB antenna
Sat Apr 14 2018 12:44am |
