Home > Technical > Shaking stearing wheel - 2009 3.6 tdv8 |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
get the wheels balanced first and then go from there.. |
Thu Mar 29 2018 4:48pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
After a drive, check the wheel temperatures for a binding brake. A sticking caliper can cause a wheel shimmy and the offending corner will have a hot wheel. If this is the cause it may clear up with some use but equally, may require a new caliper to put it right.
Thu Mar 29 2018 5:42pm |
