Home > Technical > Clunk from front when moving off |
A bit of a shot in the dark here but could it be bushes related? Robin
Tue Mar 27 2018 10:57pm |
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 |
I had wondered that, but then it feels like front centre of the car where this is coming from and only at low speeds moving off under a bit of power. Almost as if there is slack in the prop shaft or worn gear in the diff, so it is ok under low power input and fine once moving but slips a couple of times from stop until it catches propery under decent power input ? |
Wed Mar 28 2018 8:11am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
I think you’ve answered you own question, have the front prop shaft and diff checked
Wed Mar 28 2018 8:24am |
Hmm. I'm not going to be much help here as basically I'm in the dark as much as you from your description.
Wed Mar 28 2018 8:29am |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
I don’t know if this is any help, I’ve had something similar on both our Shogun and Subaru, this was a knock that I got from the rear that only seemed to happen when pulling away, In both cases I found that after re-torqueing the hub nuts it cured the problem, I don’t really know enough about our cars yet to know if this is something similar, hopefully someone with a bit more knowledge will be along to help. |
Wed Mar 28 2018 8:30am |
