Home > Technical > Tow Bar Too Long? |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1133 |
Hi and welcome
Sun Mar 25 2018 9:13pm |
If it’s the detachable tow bar you’re talking about and specifically the attachment to the RRS then it might be that you just have to be more “assertive “ with it. But as Riverblanche says pics would help. Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Sun Mar 25 2018 10:36pm |
alex31283 Member Since: 16 Jul 2016 Location: York Posts: 8 |
Mon Mar 26 2018 7:27am |
Sorry about stating what's probably the obvious, but have you checked the workings of the tow bar without it being fitted. As far as I can remember, if you push the little silver protrusion, then the tow bar locks into place. Obviously you can't fit it if the tow bar is in its locked position so just check that you are not trying to fit it whilst locked. Once again I'm sure you've sussed this but no harm in just checking... Robin
Mon Mar 26 2018 9:30am |
Hi Eaters,
Mon Mar 26 2018 10:08am |
I'll go and check mine. Photos may follow but the pin doesn't disappear altogether even when locked. Robin
Mon Mar 26 2018 10:26am |
So Picture 1 shows the tow bar ready to be fitted - note that the main locking bar is fully retracted
Mon Mar 26 2018 10:37am |
Cheers Eaters. I'll take a look when I get back home. |
Mon Mar 26 2018 11:28am |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
Mend with a disco 4 was having the same problem and he wasn't actually pulling out the spring loaded green sleeve where the key is. He had just turned the key and it won't go in unless you also pull the green bit so that you can see the red collar. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Mon Mar 26 2018 4:49pm |
Good point Godders.
Mon Mar 26 2018 4:53pm |
Thanks for the assistance guys but I've tried and its like the large silver protrusion can't reach the hole on the receiver to go through and then lock into place. Could it be the receiver that's damaged? |
Mon Mar 26 2018 6:01pm |
That was exactly what was happening with my friends tow bar until he pulled the green bit away from the body Can you push the small silver pin in with your finger when it is unlocked ? Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Mon Mar 26 2018 6:20pm |
The receiver can rust inside and get full of all sorts of grime and dirt so would be best to clean that out first, then give it a spray of WD40 and have another go 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Mon Mar 26 2018 6:23pm |
Gooders, the small pin pushes in slightly but not a huge amount.
Mon Mar 26 2018 6:35pm |
