Home > General > Wont, start, dash warnings, faults etc... Help
Jampot1979
I decided to wash the RR yesterday.
Well today came out to use it since last parking it and washing it... It want start.
I put the key in, then hazards flash, central locking noises can be heard, dash bonging noises, dash warnings all over the place, most lights lit up. I go to turn the key and it won't even allow me to turn over.
I put a new battery on thinking that was fault. Switched the park brake switch over with a spare one. Still no luck.
Could I have damaged something while washing it? Where to check?
James
Post #552249 Sun Mar 25 2018 3:27pm
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Hi pal same as my tdv8 this morning
Have a look at my post
http://www.rrsport.co.uk/forum/topic50543.html
cheers
Mani
also got
park brake fault
HDC fault system not available
Suspension Fault Vehicle Lean When Cornering MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
REAR 9 INCH TOUCH SCREEN HEADREST TV SCREENS, WIRELESS HEADRESTS, IN-CAR WIFI MIRROR BOX FOR WATCHING INTERNET TVIE BBC I-PLAYER ETC... FROM ANDROID, WINDOWS AND IOS PHONES ON THE GO ON ALL SCREENS
Post #552250 Sun Mar 25 2018 3:40pm
Jampot1979
I just managed to get it started after disconnecting the battery for an hour. But the dash was telling me so many errors. Turned it off, went to restart and it's dead again.
Post #552253 Sun Mar 25 2018 3:54pm
Mani
Same here MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Post #552254 Sun Mar 25 2018 3:56pm
Jampot1979
I was wondering if when I washed it that water has got on something.
Hmmm... Hopefully I can get it looked at tomorrow.
Post #552257 Sun Mar 25 2018 4:04pm
Jampot1979
Well... I think I fixed it. Noticed the negative battery connection was loose even when the clamp nut was done up tight. So I played around with it and got it tight on the battery.
It started up straight away, all warnings and lights off. Went for a drive, restarted etc. All is well again.
Post #552264 Sun Mar 25 2018 5:33pm
Mani
Thanks Pal, i will try that
Mani Bow down Bow down MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Post #552265 Sun Mar 25 2018 5:41pm
Jampot1979
Let me know how you get on
Post #552266 Sun Mar 25 2018 5:51pm
Mani
will do MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Post #552268 Sun Mar 25 2018 5:53pm
Jampot1979
Any luck?
Post #552333 Mon Mar 26 2018 12:48pm
Mani
Hi Pal no luck, so had it on a low loader and had it dropped to my local Indy, as soon as i hear anything i will update
Mani
Big Cry Big Cry Big Cry MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Post #552357 Mon Mar 26 2018 7:09pm
Jampot1979
Sorry to hear that... Hope it's a simple cheap fix.
I took mine to an Indy today. They cleared the logged codes, made sure earth points and battery connections were good. They had it all day and used it etc. Still all ok so fingers crossed.
Post #552367 Mon Mar 26 2018 8:09pm
Mani
Glad to hear it, hope yours stays well Thumbs Up
Bow down Bow down Bow down MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Post #552368 Mon Mar 26 2018 8:14pm
Scrumpy
Good luck Mani, hope you get it sorted easily (and cheaply!) 2016 RRS SVR Estoril Blue
Post #552373 Mon Mar 26 2018 10:02pm
Mani
Thanks, Scrumpy MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Post #552379 Mon Mar 26 2018 10:59pm
