Home > Maintenance & Modifications > Android install
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Android install
Decided to have a go at an Android install. Ford Android fits well with some fetling. Just need to paint it now.
Post #552214 Sat Mar 24 2018 11:30pm
looneyfitter
Picsin gallery
Post #552215 Sat Mar 24 2018 11:31pm
Cymruambyth
Wales
Looks tidy. Was it difficult to do? Steve.
Post #552227 Sun Mar 25 2018 8:53am
looneyfitter
Very easy pal suprisingly. Took about an hour to cut and bond the fascia. Cable kit took a couple hours.
Post #552237 Sun Mar 25 2018 11:18am
Cymruambyth
Wales
Does the top screen still work though? Steve.
Post #552258 Sun Mar 25 2018 4:16pm
looneyfitter
Yes mate. Im in the process of swapping it for a 2010 one
Post #552269 Sun Mar 25 2018 5:59pm
Cymruambyth
Wales
Nice. Usually this sort of job costs an arm and a leg, that`s why I`ve stuck with the old outdated system. Steve.
Post #552325 Mon Mar 26 2018 11:59am
DEVON
A Write up of parts used would be interesting Whistle
Post #552374 Mon Mar 26 2018 10:03pm
looneyfitter
hi Devon this is the radio i used. and the fascia will also link the adapters for other bits
https://www.ebay.co.uk/itm/HD-Android-7-1-...SwEaBaCulS
https://www.ebay.co.uk/itm/Range-Rover-Spo...SwsuhambAE
Post #552911 Sun Apr 01 2018 9:04pm
DEVON
Excellent, thank you very much Thumbs Up
Post #552923 Mon Apr 02 2018 8:06am
geoffsnook
Did you also use the incartech kit for the top screen Thumbs Up
Post #552925 Mon Apr 02 2018 8:40am
looneyfitter
yes I have now fitted a 2010 Range Rover top screen tho. All works fine. Smile
these are the other bits. Top link is the site it is from, double check on there as they are sound system specific. I have Harmon Kardon, not logic 7 hth
https://incartec.co.uk/Landrover/1791/1036
https://incartec.co.uk/Pages/Product.aspx?P=4873
https://incartec.co.uk/Landrover/1791/1036 This lead is so you can keep the nav screen audio to front speakers. I havent fitted mine yet.
You also need a patch lead for the steering controls depending on what head unit you have bought, only 3-4 poond
Post #552965 Mon Apr 02 2018 4:01pm
