Home > General > No Audio?, help! |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
let the vehicle go through its checks and wait for all the warning lights to go out, if not then that could be your issue. Had the same on my 2011 and I always let it go through its check process with now further issues |
Mon Mar 19 2018 11:48am |
Danny1 Member Since: 25 Nov 2016 Location: Essex Posts: 61 |
Hi Scousefly,
Mon Mar 19 2018 12:14pm |
So when I left work yesterday I made sure I let the checks run as per normal and the audio was back but this little gem appeared! As previously mentioned I have had this come up if I'm a bit hasty with the crank but that was definitely not the case?, It cleared after a restart and the audio was also fine this morning! so who knows! Regards, Danny |
Tue Mar 20 2018 11:19am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
Danny,
Tue Mar 20 2018 12:01pm |
Hi PC76,
Tue Mar 20 2018 12:17pm |
A knackered battery can do all these things you say plus a lot more as well get a volt meter across the terminals and see what you get static and then with the engine running and also with it running and everything electric on |
Tue Mar 20 2018 4:31pm |
Hi Geoff,
Thu Mar 22 2018 3:45pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 |
These are very battery sensitive, get it on a C-tech charger. SVR 2018 in Santorini Black. |
Thu Mar 22 2018 3:50pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
I used to get a no audio issue on my MY08 TDv8 sport, everything would function as normal and there wouldnt be any fault codes, but no sound would come out from any source. Disconnecting the battery for a couple of seconds would solve the issue, then it would come back a few days later. Theres a guide on how to do a reset on the system, you dont need to do that, just follow the guidance about waiting for it to not be doing anything, then lift the negative terminal. Hardest part is putting the cover back on the battery box!
Thu Mar 22 2018 3:52pm |
Hi d-9,
Fri Mar 23 2018 11:44am |
Get it teated the quicker you do that the quicker you will know what is what |
Fri Mar 23 2018 12:11pm |
Well I have not had the issue again? so so far so good!
Mon Mar 26 2018 6:57pm |
