Home > Faults & Fixes > Headlight bulb gone purple |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
All depends on the age of the car ! Early RRS1 had D2S bulb and later facelift cars like mine have D3S bulbs so might help if you state age and L320 or L494 ! 2017 SVR. SVO Scafell grey Ebony interior
Wed Mar 14 2018 7:05am |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
I’ve got an 06 l320 |
Wed Mar 14 2018 7:31am |
Should be a D2s xenon bulb then. Quit often an idea to change both as could end up with 2 different colours if not the same bulb spec 2017 SVR. SVO Scafell grey Ebony interior
Wed Mar 14 2018 7:54am |
Is there any certain make I should get ? I’ve never had these lights before so I’m a total newbie sorry |
Wed Mar 14 2018 8:04am |
Also what power are they ie. 4300k - 6000k !!! |
Wed Mar 14 2018 8:32am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
The type of bulb (D2S etc, H7 etc) is moulded in to the top of the headlight plastic. You can read it when you open the bonnet. Easy to check and avoid buying the wrong bulbs. 2012 SDV6 - it's missing a couple of cylinders
Wed Mar 14 2018 10:25am |
That’s brilliant thank you for the info I will check soon as I’m out of work |
Wed Mar 14 2018 10:40am |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
[quote="Wayneclarke"]Also what power are they ie. 4300k - 6000k !!![/quote
Wed Mar 14 2018 7:10pm |
Yeah sorry that’s what I meant, I took the light out earlier and the bulb is an osram xenarc 4300k so I’m thinking of replacing with the new osram night breaker |
Wed Mar 14 2018 7:13pm |
The only issue with the nightbreaker, it makes your other lights (sides and corner) look very yellow. The nightbreakers are good but have a blue tinge. I fitted them to my previous RRS when one of my lights went pink. MY12 RRS HSE
Wed Mar 14 2018 7:22pm |
I’ve ordered them now so see how they go at worse I can always buy original again |
Wed Mar 14 2018 7:50pm |
