Home > Technical > BATTERY OR ALTERNATOR ???
Bulldog
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi
ive had a few electrical related warnigs over the last few days, airbag fault, forward alert not available, handbrae fault all once the car has started for about 20 secs.
On Friday i noticed a whine coming from the engine bay which is speed related.
Having had electrcial warnings on my previous RRS just before the alternator died i checked the battery voltage this morning after car had been stood overnight and had the following reslts :
Battery voltage 11.42v ( with IGN on no load lights etc off )
Battery voltage of 10.97v ( with engine running again no load lights etc off ) this voltage rose to 12v after about 1min of running.
So do you think its battery or Alternator "the whine makes me suspicous" or indeed both ???
cheers
Post #551166 Tue Mar 13 2018 7:56am
Eaters
Alternator!
Voltage should be much higher with engine running if alternator is doing its job. Care or it will take your battery with it. At 11.4 volts battery is marginal already. What does it read with ignition off and car asleep?
I was getting similar symptoms just before my alternator went Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #551169 Tue Mar 13 2018 8:06am
Brit Plumber
Is it easy to isolate the Alternator to test for a short time, i.e. with it isolated, does it whine? I know these Li-On batteries can give very odd symptoms. If my wife has had the heated seats and screen on during cold spells (Ford Mondeo), I can be 99% certain i'll get issues with the clocks working randomly, the radio doing its own thing and the auto wipers randomly working. A good charge and a reset fixes all this. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #551171 Tue Mar 13 2018 8:11am
Bulldog
it measures 11.47 with no ign on.
When I did the last alternator on my previous RRS I put a new battery on at the same time. as bettery light came on and things like radio and heated seats would not work.
I also think Alternator is on its way out. Big Cry
Post #551172 Tue Mar 13 2018 8:14am
Eaters
When mine was on its way out I called out Green Flag as the car wouldn't start.They jump started it and then tested the alternator in situe so its not a difficult task to get it checked. Just keep your battery well charged - CTEK or similar.
First signs of a low battery for me was, after starting, the display briefly showed Auto Handbrake Release not functioning but that message went away after about 10 seconds. However, when the alternator finally gave up the ghost, a run or just 109 miles totally knackered the battery. Robin
Gone:
MGZTT 190 2.5
Post #551174 Tue Mar 13 2018 8:22am
shepp
The alternator looks like the culprit, you should be looking at around 14.5volt with the engine running.
The battery will be barely charging with a PD less than 1 Volt, hence your battery will be low. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #551247 Tue Mar 13 2018 8:50pm
