Home > Maintenance & Modifications > fitting side steps to 2007 RR sport |
Fortunately - the removal & replacement of the side steps themselves is the easiest part of the whole process . I have replaced 2 sets & only ever needed to use the steps themselves - the brackets left on the Sport have always been in good shape. Again the circa £120 steps are IMO value for money & will do the job needed. The steps are secured to the 3 brackets each side by nylon lock nuts ( 12 each side if I remember rightly). The only issue you may encounter is lining them up which can be fixed with a large hammer I had to use washing up liquid on the top lip of the plastic to aid the sliding in & out of the step whilst lining up the holes for the nuts & bolts.
Fri Mar 09 2018 8:05am |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 |
I went for after-market ones on my RRS S/C, look excellent at a fraction of the OEM cost.
Fri Mar 09 2018 10:07am |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
There is a YouTube video showing exactly how to remove and refit them think it was by powerfuluk
Sun Mar 11 2018 10:53pm |
