Home > Maintenance & Modifications > 2009 V8 HSE - banging noise
Viper61
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Hello all, been lurking for a while and found some great help / tips on here.
OK so now I have a problem which I hope you experienced RRS owners can guide me on. This morning whilst driving home my RRS developed the most horrid banging noise from the front o/s wheel area. I immediately stopped but every time I pulled away it returned (loud enough for people on the other side of the road to stop & look!). So after a couple minutes sat there I reversed back (a car had now parked in front of me) and drove off - noise stopped. Have since taken it for a drive and its very intermittent BUT seems to be when I turn hard right (mini roundabout etc) but not all the time. Its a dreadful noise which remains when I pop it into N and roll along. It varies with speed but not as direct as I might imagine.
You can imagine all the hours going through my mind but welcome any experience / thoughts / horror stories!!!
Big Cry
Post #550374 Sat Mar 03 2018 10:42pm
geoffsnook
I have just had a noise coming from the front that I thought was the off side but after a lot of looking we found my front prop was knackered don’t think it was a bang noise but depends on what you call a bang it as making a noise and above 50 it made a rumble noise
Post #550390 Sun Mar 04 2018 8:33am
Camelrock
Could’ve anything from a CV joint to a loose wheel only way is jack up the car and investigate, good luck 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2010 Freelander current
1994 Dakar current
Post #550393 Sun Mar 04 2018 8:55am
Viper61
*UPDATE*
After the intermittent noise became worse to the point of breakdown / recovery on a Friday night we have an answer from my local Independent Specialist. During the latter part of the week whilst no noise I did find that occasionally the brake pedal went 'long' resulting in little / no brakes!!! A second pump on the pedal and all good but it got to the point where it was too often to safely drive on!
2 minutes at Indep this morning and diagnosed as N/S hub bearling collapse - the lateral movement on the disc being enough to ease the pads back hence the long pedal. Booked in for e new hub assembly and hopefully back on the road later this week. Whilst there also opted for new compressor as suspension faults / wonky stance have become too much!
Now awaiting the bill Big Cry
Post #550920 Sat Mar 10 2018 3:35pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: 2009 V8 HSE - banging noise
Big Cry
I had the same noise problem on my RRS 3.0 MY60 Sort of clatter on going around mini roundabout.. It turned out to be ARB Bushes. Had them changed for poly bushes Problem gone itisme
Post #553023 Tue Apr 03 2018 9:01am
