I found this, probably no use at all though, looks like six codes beginning C1B03, common bit seem to be Directional Control Valve 1 Solenoid. Is the other code UO434 or possibly UO43A ?
C1B03-
01
Directional
Control Valve
#1 - General
electrical failure
Directional control
valve 1 circuit
short to ground,
short to power,
open circuit, high
resistance, short
to another circuit
Dynamic response
control module
failure
Refer to the electrical circuit diagrams and check
directional control valve 1 circuit for short to ground,
short to power, open circuit, high resistance, short to
another circuit. Check and install a new dynamic response
control module as required
C1B03-
12
Directional
Control Valve
#1 - Circuit
short to battery
Directional control
valve 1 circuit
short to power
Directional control
valve 1 failure
directional control valve 1 circuit for short to power.
Check and install a new directional control valve 1
solenoid coil as required
C1B03-
14
Directional
Control Valve
#1 - Circuit
short to ground
or open
Directional control
valve 1 circuit
short to ground,
open circuit
Directional control
valve 1 failure
open circuit. Check and install a new directional control
valve 1 solenoid coil as required
C1B03-
18
Directional
Control Valve
#1 - Circuit
current below
threshold
Directional control
valve 1 circuit high
resistance
Directional control
valve 1 failure
directional control valve 1 circuit for high resistance.
C1B03-
19
Directional
Control Valve
#1 - Circuit
current above
threshold
Directional control
valve 1 circuit
short to power
Directional control
valve 1 failure
C1B03-
1D
Directional
Control Valve
#1 - Circuit
current out of
range
Directional control
valve 1 circuit
open circuit, high
resistance
Directional control
valve 1 failure
directional control valve 1 circuit for open circuit, high
resistance. Check and install a new directional control
Wed Feb 21 2018 9:33am |
