Home > Maintenance & Modifications > Locating an oil leak. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
Hi mate,, I know it's not much help but I have the exact same issue. Had the problem for a good while now, it might be coincidence but I'm sure it started when I had an egr valve replaced. Only ever got one or two drops on the drive,, then it stopped for a good while, then all of a sudden started again. Very intermittent, I have actually bought a boroscope ( mini flexible camera) so I can look into the dark depths to try and locate the leak but not got round to it yet. My first thoughts were the turbo area 2010 RRS, TDV8
Tue Feb 20 2018 8:01pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Sounds like the crank case ventilation system vent hose. It runs from an oil separator at the rear of the engine V and discharges fumes in the right hand air intake upstream of the turbo. I guess that over time it might become porous or there is a small leak near the top which is working its way down the hose under gravity. 2012 SDV6 - it's missing a couple of cylinders
Tue Feb 20 2018 8:55pm |
Left4dead Member Since: 03 Feb 2018 Location: Newcastle Posts: 7 |
Alright Gogsy, I’ve got one of those and tried to use it today but going from the underneath it doesn’t give off enough light to see clearly enough, just had a thought, might open the bonnet to see if that lets a little more light through, doubt it but it can’t be any worse lol.
Tue Feb 20 2018 9:35pm |
