Home > Technical > Limp home mode.
Andy B.
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Limp home mode.
MY10 RRS went into limp home mode recently. RAC called out and found oil on air filter and mass air flow sensors. Turbo making an unusual whooshing sound on rev reduction. Turbos removed and sent away for examination. No problem with turbos on initial inspection other than oil being present. Fault code was regarding the mass air flow sensors. Any one have any ideas where the oil may be coming from and why there is an unusual noise sounding similar to a dump valve?
Post #548480 Tue Feb 13 2018 12:19pm
when the turbo VVT is jammed, you get the woosh noise when the revs drop.
You would have the engine light on though I would have thought
Post #548484 Tue Feb 13 2018 1:02pm
Andy B.
Limp home mode.
Thanks Andy. Turbos been returned tomorrow. Would really like to know where this oil is coming from?
Post #548485 Tue Feb 13 2018 1:21pm
Disco_Mikey
TCOV seized. Known issue. Nice, cheap repair
Assuming the MAF's are not actually at fault. Which begs the question, why are the turbo's off? Confused
Post #548486 Tue Feb 13 2018 1:22pm
Andy B.
Limp home mode.
Thanks Disco Mikey.RAC called out. Read fault codes, checked air filter and air mass flow sensors. Oil everywhere. Diagnosed faulty turbo. Vehicle under 2 year warranty so turbos taken off and sent to specialist for examination authorised by warranty company. Will pass on info to indie and hope to have everything re installed by the weekend. Any other ideas where the oil originated?
Post #548499 Tue Feb 13 2018 2:45pm
