Home > Maintenance & Modifications > I can't keep it up.
HughN
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
I can't keep it up.
Morning All,
For most of the time my '07 RRS sits on the road. If I set it to offroad height it will be sitting at access height within two days (apart from one wheel which is even lower). It needs fixing but is a gradual descent over two days 'within normal range'? The pump doesn't run during normal driving.
I did consider putting some garlic paste round the inlet of the pump, then having a good sniff around for the leak! Laughing "I am never content until I have constructed a model of the subject I am studying. If I succeed in making one, I understand; otherwise I do not" - Lord Kelvin
'06 RRS 2.7 TDV6 HSE
'14 D4 3.0 TDV6 HSE
Disco II Td5 - gone (went to Africa)
Disco I V8 - gone (no engine, brakes or power-steering but towed away by a Suzuki Jimny on a 6ft rope)
Disco I V8 - gone
[Plus two Freelanders I'd rather forget but my wife liked]
Post #548015 Thu Feb 08 2018 7:59am
It's typical of a car of this age.
Infact 2 days is very good. A lot can't even manage 1 night without drooping Laughing
Once one wheel goes down the car self levels and so they all follow.
You can remove a 20A fuse under the bonnet overnight to see which corner is causing the problem.
Seals may require changing in the valve blocks (£17 off ebay) and a good clean out.
Front one is easier to do
Post #548029 Thu Feb 08 2018 12:05pm
HughN
Thanks, I'll remove the fuse and see what happens.
Cheers,
Hugh "I am never content until I have constructed a model of the subject I am studying. If I succeed in making one, I understand; otherwise I do not" - Lord Kelvin
'14 D4 3.0 TDV6 HSE
Disco I V8 - gone
Post #548031 Thu Feb 08 2018 12:30pm
