Home > Faults & Fixes > Turbo Chatter / Surge - Is this normal 2012 (old shape) SDV6
RRS2012
Hi Guys,
My stock 2012 RRS SDV6 (old shape) has started making a turbo flutter noise when the throttle is released after putting the engine under load. I noitced it reversing up my drive, it rather steep. But I can also make it do it by breaking and just reving the engining and letting off while in drive. sound like a pap pap pap pap sort of thing (hard to descripe
I've inserted a youtube vid here of the exact same noise I found on youtube
Steeler is telling me this is normal, a normal intake sound. What are your thoughts. I was wondering if anyone has the same noise and it is infact normal. Is this normal? or a turbo failure in the making. I thought it could be the BOV misbehaving or one of the other compensating valves between the two turbos one of the valves that need changing
thanks
Post #547376 Fri Feb 02 2018 1:22pm
RRS2012
I realise this is posted in the wrong place, have re-posted in the correct section
MODs please remove this if poss
Apologies
Post #547447 Sat Feb 03 2018 1:07am
