Home > Technical > Interior lights |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
could be expensive. Like a CJB fault.
Wed Jan 31 2018 7:03pm |
GavinNicholas Member Since: 06 Oct 2017 Location: KT81NY Posts: 3 |
I'm not sure what a CJB is but I have just remembered that when the number plate bulbs blew there was no error code reported which I believe there should be.
Wed Jan 31 2018 7:08pm |
The early RRS didn't have bulb failure monitoring
Wed Jan 31 2018 7:45pm |
Thanks At least I don't need to worry about that not working! |
Wed Jan 31 2018 7:50pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Is it fuse No. 57 that you have checked ? as that is the Interior light fuse but as I think the map lights and sun visor mirror vanity lights run of the same fuse that does sound like it is o.k. I think initially it I would double check they are switched to automatic, you say you have found out how to do this as it is simple enough, press and hold interior light button until they flash and should show message on info. screen in dash.
Thu Feb 01 2018 12:13pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
You're not expecting the rear courtesy lights to come on with the rear doors open are you? Merc C220 estate Sport AMG
Thu Feb 01 2018 1:59pm |
