Home > Wheels & Tyres > Tyre tread pattern explanation please
Stevepd
Well I'm bored stiff at work with nothing to do. Anyway I cleaned my recently removed wheels last night which have Michelin Latitude Sport tyres fitted. Now I was marking them up as which were front and rears and which side they came off so I could put them back on the same hub they came off of. I noticed that for want of a better phrase the shaped groove that's on the outermost of the tyre (outside face) face one way. So for example if I have the tyres one the LHS the shaped groove faces the rear of the car and the RHS will have them facing the front.
So for the knowledgeable out there how does this affect the grip and feel if at all?.
Steve. Big Cry 2006 2.7 TDV6 HSE in Cairns Blue.
Post #546599 Wed Jan 24 2018 8:32am
Have the tyres been fitted the correct way round as I think the latitude sport is a Asymmetric tyre and there should be a marking on the tyre saying "Outside" which obviously goes to the outer face of the wheel rim although the rim can be fitted either on the O/S or N/S of the vehicle as long as "outside" is to the outside it is fine.
Post #546608 Wed Jan 24 2018 9:31am
Stevepd
Yep all 4 tyres have OUTSIDE on the outside. I'll try and post a photo for a better explanation.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #546611 Wed Jan 24 2018 10:08am
Stevepd
Here we go. So if you look at the groove and its orientation by the word outside. Now imagine that's fitted on the LHS of the car going forward. If you fit the same wheel/tyres on the RHS (or vis versa) the grooves go the otherway?
Post #546612 Wed Jan 24 2018 10:12am
Lindab
I have just had a look at the 20" P Zero's on my F type Jag which is hibernating. All tyres have "Outside" & as you say the grooves face forward on the offside & rearwards on the nearside Question another marketing gimmick perhaps Evil or Very Mad
Post #546637 Wed Jan 24 2018 2:48pm
riverblanche
Hi,
more to do with the tread pattern/grooves and compound so although it seems to be the pattern is going one way on the N/S and the other way on the O/S, you still have the "outer" compound and tread pattern on the outside of the tyre, as in your pic
that's as long as you don't have a "rotation" arrow on the tyre as well Question Corris HSE Dynamic 2016
Always pick up stick in the middle !!
Post #546686 Wed Jan 24 2018 8:25pm
The inside shoulder is designed with different block and groove densities to those on the outer shoulder. This is because the shoulders do different jobs, or rather are designed to deal with different conditions. Hence the different look across the tread and hence the "outside" marker. The direction of the grooves is less important here than might be expected.
The inside shoulder is designed to provide wet grip hence the greater number of grooves. The outer shoulder for dry road grip when pressing on hence the larger blocks with fewer grooves. 2012 SDV6 - it's missing a couple of cylinders
Post #546694 Wed Jan 24 2018 9:22pm
