Home > Maintenance & Modifications > Handbrake shoe re-fitting
Paddi
Been meaning to post this for a while. Sorry if it is a bit of a minority interest for those who do their own servicing.
For anyone who has or is contemplating stripping, cleaning and reassembling the handbrake as a service routine or changing the handbrake shoes - you will find Bodsy's brake Bible invaluable.
However, you may still struggle to fit the handbrake hold-down pins and springs because it is a tight space to work in and the springs are strong and hard to compress. As I think Bodsy mentions 'you need three hands for this one'.
Last time though I finally found a technique to fit them that is quick, easy and simple:
Here is a pic of a pin and spring in place so you know what we are talking about:
To fit the spring, reach behind the backplate, insert the pin through the backplate and brake shoe and hold it in place with the tip of a finger, then using the other hand, compress the spring in a pair of pliers and hold the open end at a 45 degree angle to the shoe and slip the upper 'fork' under the pin's head. Then release the pliers and the spring just pops into place.
It was easier to take a picture on the bench to show this but note in the picture the spring isn't fully compressed as you need to squeeze hard to close the open end properly:
Hopefully this might save others a bit of time and swearing! 2008 MY Java Black TDV8 HSE
Post #546198 Thu Jan 18 2018 4:14pm
