Home > General > Amber marker lamps in headlamp units
HughN
Wales
Hi,
Having taken the headlamps out of my '07 the other day, I noticed that there is provision for amber marker lamps at the side, but there is no wiring/fittings. Fair enough, but I've noticed that more recent LR products have them lighted.
Were these included just for export markets and/or has there been a change in regulations to require them? I can't see any reason to make them functional but they must have been there for a reason.
Just curious!
- Hugh
Post #546141 Wed Jan 17 2018 8:09pm
geoffsnook
They are put in for different markets you can get them going the bulb holder should be there but you need to drill out the holder if they are the same as a disco 3 and the lights are like the ones you get on the discovery 2 Thumbs Up
Post #546143 Wed Jan 17 2018 8:16pm
HughN
Wales
I'm not sure whether I really need them - they might look a bit, ahem, 'foreign'. I do have a few Discovery 2 bits in the shed - a naive attempt to keep fitting parts as quick as they fell off.
When I drove Saabs I found a cut-out in the side/indicator unit that would throw light to the sides when reverse was engaged - illegal but b****y useful and well worth ten minutes with a Dremel!
Post #546148 Wed Jan 17 2018 8:29pm
For USA
No bulb holders present on the RRS.
No drilling required.
Have fitted them to mine.
Post #546149 Wed Jan 17 2018 8:29pm
HughN
Wales
Do they look the part, Andy?
Post #546150 Wed Jan 17 2018 8:30pm
It's just a small square that lights up in the middle of the reflector.
Looks a tad boy racer but useful when inching out my drive.
Post #546154 Wed Jan 17 2018 8:40pm
