Home > Maintenance & Modifications > Timed Climate |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
There are separate settings in the car's configuration file (CCF) for remote and timed climate. If the indie only enabled timed climate, remote will not work. You say you fitted the remote module yourself ... did you also pair the remote with the car? This is done by removing a fuse and putting it back in. There is info about this on the forum if you search.
Wed Jan 17 2018 5:18pm |
Drew 8346 Member Since: 17 Jan 2018 Location: Devon Posts: 3 |
Hi
Wed Jan 17 2018 6:49pm |
Yes, easy enough so worth a try. Normally if the FBH doesn't start EVER, it suggests it needs purging/resetting but you have already mentioned it runs when you start the car so that can't be it. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Wed Jan 17 2018 6:59pm |
This may not help, but then it just might. And it’s an easy process.
Wed Jan 17 2018 9:37pm |
The indie did this when re setting the remote to rue it out but still nothing.
Thu Jan 18 2018 9:48am |
