Home > Technical > Range Rover Sport 64 plate Hybrid - Battery Change |
Shouldn’t need coding to the car. In 2011 I had to replace (under warranty) the battery in a 2011MY Evoque and with that the Battery Management System required resetting after replacing the battery. You should check if the battery you are replacing is an AGM battery and replace it with the same. In October 2017 I found my car (a 2015MY) had a totally dead battery, LRA came out and jump started the car but didn’t need to do anything else so I assume that BMS has been reprogrammed/ designed since my 2011 espisode. I don’t know if Plug In Hybrids have anything special and would be interested to know as I have a Plug In coming in April. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Jan 16 2018 2:08pm |
