Home > General > Help please bottom front wishbone tdv8 |
If your doing it i would change the whole arms unless you have a ramp and all the tools they can be to get off and out but its really up to you powerflex bushes will last longer. Or you can source a pair of knackered bottom arms from ebay and refurb them with the new bushes either normal or powerflex then they will be ready as soon as the old ones come out and may save you a bit on garage labour or your time |
Thu Jan 11 2018 7:45pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Call Advanced Factors in Southampton.
Thu Jan 11 2018 8:49pm |
Tel02sport Member Since: 02 Jul 2017 Location: Surrey Posts: 14 |
I have access to a two and four poster ramp and press thanks for you advise I think I will bush it my car has only done 35000 miles so arms are in good condition so will fit bushes too my arms thanks again ๐๐๐ |
Thu Jan 11 2018 9:38pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8838 |
The issue isn't the condition of the arms, it's whether you can get the bolts out. They usually seize in the bushes and the easiest option is to cut the arms off. If you're doing it yourself then time taken to free the bolts might be less of an issue. If paying someone else then it's usually cheaper to buy and fit new arms.
Thu Jan 11 2018 9:47pm |
So new boots are poss needed to get the job done too ??? |
Thu Jan 11 2018 10:02pm |
As said by RRSTDV8 it does not matter if the bolt donโt want to come out it wonโt trist me I know I have done it twice so new bolts can be needed also seen people cut the arms to get them out but if they come out ok then use super pro as they are softer than polly bushes and not so harsh |
Thu Jan 11 2018 10:08pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4333 |
Superpro bushes are designed to be as compliant as OEM rubber bushes, while lasting much longer
Fri Jan 12 2018 8:06am |
Where can I buy super pro bushes ? |
Mon Jan 15 2018 4:20pm |
I think advance factors sell them or try ebay have seen them on there |
Mon Jan 15 2018 4:44pm |
Ok thanks Geoff great help |
Mon Jan 15 2018 5:45pm |
