Home > Technical > Parking sensor testing |
Gandalf Member Since: 11 Sep 2017 Location: South Killingholme Lincolnshire Posts: 205 |
Hi all can you test the parking sensors with the Gap tool mine are not working .
Tue Jan 09 2018 6:08pm |
Where is it had a look but couldn't find the section. Only came this morning so got L plates on ATM could find my way round a nano on my TD5 but this also cleared all the historical faults so see if anything comes up. If it ain't broken down it soon will
Tue Jan 09 2018 8:11pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
What's the issue with them. |
Tue Jan 09 2018 8:15pm |
Continuous beep on startup light on the dash is flashing and no sound. Smacked into a gate post this morning luckily just chipped some paint off the bumper corner thought I'd smashed it at first. If it ain't broken down it soon will
Tue Jan 09 2018 8:24pm |
Read the fault codes then |
Tue Jan 09 2018 8:53pm |
Will do tomorrow. If it ain't broken down it soon will
Tue Jan 09 2018 9:55pm |
Hi Andy cleared all the faults took it for a run this is what has come up.
Wed Jan 10 2018 2:56pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 867 |
Don't think I shall be buying a fault code reader. Ignorance is bliss |
Wed Jan 10 2018 3:02pm |
Don't think I shall be buying a fault code reader. Ignorance is bliss.
Wed Jan 10 2018 3:49pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1239 |
2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Jan 10 2018 3:59pm |
Think you can safely ignore the first four under 'Ventilation' I always see those fault codes and the HVAC works fine. Seem to remember it was no less than the supremo Disco Mikey who pointed that out some time back?
Wed Jan 10 2018 4:48pm |
@Paddi
Wed Jan 10 2018 5:01pm |
Front right inner sensor |
Wed Jan 10 2018 7:10pm |
My thoughts exactly just thought I'd post as it also mentioned U0159-87 (2E) Lost communication with parking assist control module - Bus signal/message failure - missing a message just wanted confirmation it was the sensor. Thanks again Andy If it ain't broken down it soon will
Wed Jan 10 2018 7:14pm |
