Home > Maintenance & Modifications > Big brakes😬 |
scousefly Member Since: 24 Jan 2015 Location: sheffield Posts: 248 |
Ally but would these fit the L320 2011, the seller says they wont but not sure? Would they need any mods if they do fit
Tue Jan 09 2018 7:27pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4816 |
Brembo Calipers mount direct to the stub axle, rear calipers on a L320 are mounted on a carrier bolted to the stub axle. Unless you can find a pair of carriers with the correct mounting hole centres for both stub and caliper, as brembo calipers do not slide they would also need to centralize the caliper to disc as well.
Tue Jan 09 2018 8:55pm |
Allycarson Member Since: 04 Jul 2017 Location: Dumfries Posts: 24 |
Yes scousefly bolt strait on that’s what I have on mine off a current sport |
Tue Jan 09 2018 10:11pm |
Tue Jan 09 2018 10:13pm |
Fronts might, rears certainly don't.
Tue Jan 09 2018 10:17pm |
Don’t suppose you know the brembo part number for the rear conversion caliper do you col or what else they might be on thanks |
Mon Feb 05 2018 8:33pm |
Hi,
Tue Feb 06 2018 6:45am |
